how do you turn the boost down as i hit fuel cut and dont wanna big repair bill as someone said it was v bad
Well have you got an adjustable actuator fitted?
Im assuming youre not running a boost controller..
what mod have you fitted to be hitting fual cut?
i dont really know i havnt done anything to the engine it looks pretty standard from what i can c as it only has a hks airfilter (green one) fujitsubo exhaust but still has a cat on it and its got a blitz dump valve and looks like a standard actuator with slightly bended arm. so should it not hit fuel cut then. what could be the problem?
If the stock actuators arm is bent, the wastegate will be opening more, hence boosting higher.
Looks like you need a new actuator, in which case go for the hks item.
are they easy to fit?
