ramses Posted March 17, 2015 Share Posted March 17, 2015 " car will stall on deceleration or idle when stopped at light, sign, etc. It won't start for 15~30 minutes. When I do get it to start, Gas peddle all the way in and hesitates (stays at ~800 RPM steady) until it burns off fuel and then rises RPM rapidly to match WOT. fed up ignitor is new/DIs is new/spark new etc any ideas ??" Quote Link to post Share on other sites
funny onion Posted March 17, 2015 Share Posted March 17, 2015 Coolant temp sensor? Quote Link to post Share on other sites
ramses Posted March 17, 2015 Author Share Posted March 17, 2015 Coolant temp sensor? i do not know how cani check it ,because on the EMU i can see the voltage ,and the degré...it seems working normaly Quote Link to post Share on other sites
funny onion Posted March 17, 2015 Share Posted March 17, 2015 Change the coolant temp sensor, the EMU won't see the reading from the coolant temp sensor anyway. Quote Link to post Share on other sites
ramses Posted March 17, 2015 Author Share Posted March 17, 2015 (edited) can you tell me where can i get by internet this parti am in reunion island ,and there is no 4efte parts to get , i have to take all from englandthanxin fact i need the part number to find it??is is the same as 4efe? Edited March 17, 2015 by ramses Quote Link to post Share on other sites
ramses Posted March 17, 2015 Author Share Posted March 17, 2015 (edited) can it be the IAC valve or IAT ??because this is very strange , i can drive during 30 min and after that will stall on deceleration or idle when stopped at light, sign, etc. It won't start for 15~30 minutes.After that i can crank it again and run etc etc ... Edited March 17, 2015 by ramses Quote Link to post Share on other sites
nano Posted March 17, 2015 Share Posted March 17, 2015 Salut ramses amayama.com 35e shipped for coolant sensor.89422-35010 if it is the 2 pins sensor. Quote Link to post Share on other sites
nano Posted March 17, 2015 Share Posted March 17, 2015 Water sensor 89422 35010 for the 2 pins sensorIat 89424 24010Amayama.com Quote Link to post Share on other sites
ramses Posted March 18, 2015 Author Share Posted March 18, 2015 Thank you Nano, where are you in REunion island? Quote Link to post Share on other sites
