*sean_glanza_v* Posted March 23, 2015 Posted March 23, 2015 Need a set of these to finish doing my levin brake setup conversion Would ideally like bolt on ones but ones that just slide on will do After 10/20mm spacers
Matt1878 Posted March 23, 2015 Posted March 23, 2015 I have 15mm solid spacers if they are any good? £20+ postage?
*sean_glanza_v* Posted March 23, 2015 Author Posted March 23, 2015 Was really after the bolt on ones or like above with the hub lip in the middle so the wheel rests on that and not the studs
Matt1878 Posted March 23, 2015 Posted March 23, 2015 These ones are alright you just need extended studs as there 15mm
