Profec b spec 1
Alright folks , checking to see if anyone has got one installed on glanza ? Have mine installed yesterday and trying to set the high boost but it keeps dropping to .6 or jus over it.(it will go to .8 or just above )Have the IN pipe on profec motor box to turbo and OUT to actuator and other outlet on actuator blocked off also the factory boost solenoid blocked off and the controller is teed into boost gauge ? Low boost will hold at .5 but if I turn it up will drop to .5 ? Anyone got any experience using these ? Any help much appreciated😃👍 costing me a fortune in petrol trying to set it 😂. Hopefully someone can understand that 😁
Ya can close this or delete it. I got it sorted today I changed the actuator to hks one today set it low and turned the boost up using controller to .8 and it'll sit there all day,So I'd say it was the actuator shagged.
