onnaj1000 Posted April 1, 2015 Posted April 1, 2015 Hi, I did find out that my Starlet EP91 is leaking oil from the front main seal. I do have to change the timing belt soon anyway, so i better change the seal at once. What i'm wondering though is if i could replace the main seal without removing the oil pump housing, Or is it advisable the replace the oil pump seal at the same time? Don't think it's leaking from there though. Any special tools needed for the seal removal? Usually they pry it out with a screwdriver, i think the 4EFE will be no different? Thanks Quote
5e colin Posted April 12, 2015 Posted April 12, 2015 he omnaj use smal drill bit like3mm and drill 2 holes at 12 and 6 or wich ever you get the idea then screw 2 srews in there and wiggle it out DO not pry it out with screwdriver or you might scratch the housing or scratch crank in both cases it will leak then and never seal again also if u want new pump go ebay.com and lok for 5efe paseo pump there cheaper on there delivered and customs then buyin over ere Quote
onnaj1000 Posted April 13, 2015 Author Posted April 13, 2015 Hi,Thanks! I don't want a new pump though, just wondering if I should replace the oil pump seal also? The pump is fine and I'm not going to change that :-) Quote
