Just noticed a slight oul leak underneath right hand side. Theres oil drips in the under plastic and on the bottom arm i think, next to right hand front wheel
Could it be the sump?
Could be the crank seal mate, think that's what it's called, someone will put me right haha but if you can jack car up and spray brake cleaner so it's all clean then start car up and see if you can see where it's coming from probably an easier way but just thinking of top of head
