The only time a harness should be used is with a cage and a fixed back bucket seat.
It is possible to run a harness through a harness bar and then down to the rear seatbelt mounting points, this isn't the best way but it tries to keep the angle correct, 15 degrees off the top of my head. This will still require a fixed back bucket seat.
If you want to be picky then this still isn't ideal as anytime a harness is used, realisticly a HANS device and associated helmet should be used as well because a harness keeps your body in place but not your neck, and again upon impact this can cause damage.
Using a harness any other way than mentioned is plain stupid, and risk serious injury.
