tango123 Posted April 23, 2015 Posted April 23, 2015 dropping down the tank, an cant seem to get undone the metal fuel pipe union coming out top of the pump that joins to the line that goes towards front of the car. any ideas?? Quote
Scoobysvx Posted April 23, 2015 Posted April 23, 2015 If it's just the pump you need to change there's no need to drop the tank out, you can access it from the top. Remove the rear seat bench, on the passenger side there's a metal cover, remove this then you'll have access to the bolts that hold the pump in place Quote
tango123 Posted April 23, 2015 Author Posted April 23, 2015 thanks for the reply but stripping down to shell an building her back up. thats why i got to get it off Quote
5e colin Posted April 23, 2015 Posted April 23, 2015 its a 14mm and 19mm spanne u need if it wont budge put a vice grips on the 14 to get more leverige it will loosen Quote
tango123 Posted April 23, 2015 Author Posted April 23, 2015 cheers matey. will just have to give it a bit of stick then to get it to budge. damn thing Quote
5e colin Posted April 23, 2015 Posted April 23, 2015 hold the 19 steady and try to move the 14 otherwise it might bend snap !!! Quote
tango123 Posted April 24, 2015 Author Posted April 24, 2015 yup thats what i was worried about, will have a go at the weekend. fingers crossed Quote
