mikeyD5643 Posted April 29, 2015 Posted April 29, 2015 Well lads I have a 6 speed lsd gear box in my glanza but I need a shifter and cables... does anyone know wat will work or wat I can do or if anyone has made same conversation? I tryed a levin shifter but the holes dont line up?? Any replys or advice be appreciated cheers Quote
morgey Posted April 29, 2015 Posted April 29, 2015 You can notch out your shifter to allow the extra movement for reverse Quote
mikeyD5643 Posted April 29, 2015 Author Posted April 29, 2015 Like you mean on the plastic part on the shifter? Do I need change the cables aswell? Quote
morgey Posted April 29, 2015 Posted April 29, 2015 yeah basically if you push the shifter to the left past where 1st/2nd is you will notice something somewhere of the main housing stopping it from going further basically cut away where its hitting lol. I think its underneath it.As for the cables im not sure you might need to put the cable holder from your old 5speed box onto it to use your cables. Its worth a try before buying new ones. Quote
funny onion Posted April 29, 2015 Posted April 29, 2015 I used the original starlet cables. Just notched the shifter housing to allow it to select reverse. Quote
Ryan_EP82 GT Posted May 5, 2015 Posted May 5, 2015 notch the shifter housing or fit a short shifter, allows more throw to engage reverse out of curioisty was the box from a g6 or g6r? Quote
morgey Posted May 5, 2015 Posted May 5, 2015 A short shifter would do the opposite as its longer on the bottom. Quote
