I'm looking into getting a bit more poke out of my daily corolla E10, i think my engine is the 84bhp one, what is the the cheapest and simplest option for a noticible difference?
Will a MK1 GI ECU(7*00 rev limit) bring it up to 99bhp? also is it plug and play? Also what modification is needed to fit a 4efte throttle body?
Edited by wezy
4efe rolla then its no problem lay in loom 4efte ecu swap over to turbo dizzy coil igniter and map injectors and of you go the 4efte ecu is 7.5 in the glanza and 7.2 in the gt so wel worth it and will fuel the na just perfect
bimotoman will tell you when you pm him on tocirl :) :)
