Kayleighhep82 Posted May 9, 2015 Share Posted May 9, 2015 Hi guys have just fitted a second hand set of tein superstreet coilovers to my gt & when I boot it the car seems to have a lot of torque steer & seems to be all over the place? the front wheels are pointing in together? They are on the hardest setting can this sometimes cause problems? I have the car booked in with my mate who works in ats to have all the tracking sorted etc hopefully this sorts it all out? Also on the adjustable top mounts would anyone advise to run camber or not? Quote Link to post Share on other sites
RobSR Posted May 9, 2015 Share Posted May 9, 2015 (edited) If the camber on the top mounts is set wrong to your track rod ends you may have a certain amount of toe in/out. When i brought mine the front left was running positive camber with the right running neg. When i adjusted the left to match it was massively toe'ing in. Once re-tracked and setup for it it was fine Edited May 9, 2015 by RobSR Quote Link to post Share on other sites
Kayleighhep82 Posted May 10, 2015 Author Share Posted May 10, 2015 Okay great thank you ☺️ It's booked in to a garage now to to get them right & re-tracked Quote Link to post Share on other sites
