Tintin_SR Posted February 14, 2008 Posted February 14, 2008 OK so you hear it all the time, "" what dues that mean"" i think it wood be a good idea to make a section or a sticky that has all the words and acronyms/abbreviations to do with cars and EP, you no like FMI TMI o/s n/s just so people no wood be a bit of help to newbies and just in general Quote
Guest Enzo Posted February 14, 2008 Posted February 14, 2008 like this,RR - rolling roada mechine that measures the power of an engineMPG - Miles Per GallonEBC - electronic boost controllerMBC - manual boost controllerRRFPR - rising rate fuel pressure regulatora device used to adjust the presure at which fuel goes into the engineDOHC - Dual Over head CamshaftSOHC - Single Over head CamshaftTMIC - top mount intercoolerFMIC - front mount intercoolerEGT - exhaust gas temperaturePCD - pitch circle diamiterthe measurement through the wheel studs of a carAFR - air/fuel ratioEFI - electronic fuel injectionBOV - blowoff valveor more comonly known as the dump valveSLD - speed limit defendertakes away the speedcut from any import epFCD - fuel cut defendertakes away the fuel cut away from any turbo epHID - high intensity dischargelighting system found on prestigus brands- transmits a brighter light over halogen bulbsMANI - manifoldCR - compression ratioABS - anti-lock braking systemTPS - throttle position sensorTDC - Top Dead Centrea term in regards to cam gearsPSI - pounds per square incha measurement of boost along with bar.BCC - boost cut controllerBMCS - brake master cylinder stoppera device that clamps around the master cylinder to stop it from movingA/C - air conditioningECU - electronic control unitthe brain that runs an engineAFM - air flow meterEMS - engine management system in regards to full aftermarket non oem solutionsEPC - electronic parts catalogueAFR - air/fuel ratioMAP - manifold absolute pressure (sensor)ARB - anti roll bara bar that mounts to the rear that increases roll stiffness and quells understearOEM - Stands for Original Equipment ManufacturerJDM - Stands for Japanese Domestic Market - products and equipment that were intended for the Japanese market.USDM - Stands for United States Domestic Market - products and equipment that were intended for the American market.SR - Stands for 'Sport Rally'LSD - Limited Slip DifferentialBHP - Brake Horse Powerpower at the flywheelWHP - Wheel Horse Powerpower at the wheels, this is a more accurate measureWOT - Wide Open ThrottleZenki - Early modelKouki - Facelift revised modelbeen hording it until the sites up Quote
Tintin_SR Posted February 14, 2008 Author Posted February 14, 2008 lol i like that that goingon UKSC? Quote
