liam2368 Posted February 16, 2008 Posted February 16, 2008 well carrying on from http://www.ukstarletclub.com/forums/index.php?showtopic=9241i did a compression test first off tried it with the plugs out and the engine was stone cold got 1)1232)1153)1104)120then got the car started for 20seconds at tops and with the spark plugs in i got1)1302)1303)1304)140then managed to get the car upto running tempreture and it came out as1)1382)1383)1384)144when i manged to get the car somewhat warmed up the car then began to "rev" as in if you kept the foot on the gas it would gradually rev to like 5k then after dropping down removing my foot from the gas it would just cut out again, getting it started again after being warm was really easier rather then when its cold it would start every 1 in 10 attempts,the engine was shaking at first but when it got warm it sounded a little bit better and improved somewhatcan anybody help me out on what the next thing could becould it be a carb problem?coil pack? air problem or could it be a turbo problem?this has been going on for ages now and I've not even driven the car since I've bought it so any help would be very much appreciatedliam. Quote
liam2368 Posted February 16, 2008 Author Posted February 16, 2008 nope no fault code given, eventhough the engine management light does seem to be on Quote
natural born nutter Posted February 16, 2008 Posted February 16, 2008 When it runs does it smoke at all. Maybe your head gasket has gone and your cylinders are filling with coolant. Quote
liam2368 Posted February 16, 2008 Author Posted February 16, 2008 as far as im aware the car hasnt used any coolant at allthe sypmtoms of my car are...when i set off in 1st the car juddered like a kangaroo for about 5-10seconds then it wentnext day the car would not startwhen it does it seems to be missfiring somewhat and will only run with my foot on the gas pedal at 500rpm, it will not rev at allmanaged to get the car warmed up a little today by leaving the car running and putting a brick on the accelerator then it rev'd up every now and again to about 5000rpm then after let it either died or was very close to it, it was spitting out black little bits from the exhaust no smoke really Quote
natural born nutter Posted February 16, 2008 Posted February 16, 2008 Another stab in the dark but maybe your cat has collapsed inside and its blocking the exhaust gases from escaping. Quote
liam2368 Posted February 16, 2008 Author Posted February 16, 2008 nope havnt checked it where abouts is it located? Quote
liam2368 Posted February 17, 2008 Author Posted February 17, 2008 ill go hunting tomorrow for any sensors and try and check the timing.. im a timing virgin though lol Quote
