jamesh Posted July 23, 2015 Posted July 23, 2015 What could be causing my fan not to turn on. Is it the thermostat or the fan switch? Also does anyone know where i can buy these parts. Thanks Quote
AdamB Posted July 23, 2015 Posted July 23, 2015 First would be to check the wiring on the fan switch. After that then replace the switch, pretty sure ID Workz will do them or Toyota, can't imagine their that expensive. Quote
jamesh Posted July 23, 2015 Author Posted July 23, 2015 I done a volt test and it has a reading. So it must be the switch then. Think id want £21 but found some on ebay but they for a starlet Quote
AdamB Posted July 23, 2015 Posted July 23, 2015 I'm certain all the fan switches across all 4E* and 5E* engines are the same, but I'm sure someone will correct me if I'm wrong. Quote
