Can I adjust the door at all? Or do I need to replace worn parts? Can literally lift it by an inch and it's smacking off the skirt before closing 😒
I actually fixed one of these the other day pull the wing off much handier to work at I took the hinge off that was causing the agro and filled it a bit making it adjust ie move hinge back door drops move it forward door lifts so I could make it lift more even though it could lift a bit more with the hinge been worn as I didn't have any other option didn't have a hinge to replace it with
ive seen a few people take the hinge off cut the door pin take it out weld a washer over the original pin hole and replace the pin no more worn door hinge for a good while
Yeah 5 min job swapping hinges makes a great difference door close so easy...yeah got the glow barrel and footwell light fitted tapped into door switch and a ignition power
