tommcnaught Posted August 1, 2015 Posted August 1, 2015 My gt turbo is struggling to start sometimesometimes it will start straight away but sometimes i can sit there and crank it and it wont start, then if i leave it and come back it will start, any ideas?my exhaust manifold is blowing where it connects to engine would this effect it? Quote
5e colin Posted August 1, 2015 Posted August 1, 2015 no it wont do comp test low compression will couse starting check if there is no oil or water entering chambers it causes strarting to check plugs to they might be fucked Quote
tommcnaught Posted August 2, 2015 Author Posted August 2, 2015 going to have it comp tested today hopefullyhow do i check water and oil in chambers?and will also check my plugs today Quote
5e colin Posted August 2, 2015 Posted August 2, 2015 you can tell by inspecting the plugs , bore scope is very handy to if you had it you could inspect the piston tops for signs of water or oil etc but check plugs and comp first Quote
tommcnaught Posted August 2, 2015 Author Posted August 2, 2015 Found issue, Fcd stops car from starting, removed it it started straights away put it back in and it won't start Quote
