I'm looking to run 1.5/6 bar on a td04l, I just need advice on injectors, size etc. also does anyone have any links that aren't too pricey?
You need high impedance mate.
try and get the newer style denso injectors though as they give a better spray pattern, smaller drops too.
You can use low impedance injectors but you will need to wire in ballast resistors on a heat sink. Usually a 25w or 50w 4R7 per injection channel will do the job.
