Bug679 Posted August 10, 2015 Posted August 10, 2015 Alright folks ,So my speedo stopped working the other day and checked the code whhich was 42 = VSS. Now i've changed the senor in the gearbox for one i know was working cause it came out of my old gearbox and it was working fine. Is there a fuse or anything for it might of gone ? Also the connection on the back of the cluster is dead on to, could that part of the cluster just of stopped working ? am at a loss here anyway Don't know why it won't workAny help appreciated Thanks Quote
Sudden Posted August 10, 2015 Posted August 10, 2015 The cable probably snapped, remove speedo cable from gearbox and cluster. Hold either end and see if the opposite end spins when you turn it. Quote
Bug679 Posted August 10, 2015 Author Posted August 10, 2015 O right, good call I'll check that out n let ya know if that's the problem thanks 👍🏻 Quote
Bug679 Posted August 10, 2015 Author Posted August 10, 2015 IT's not spinning so take it that's the problem. I take it a starlet speedo cable will work fine ya ? Quote
Bug679 Posted August 11, 2015 Author Posted August 11, 2015 ok so got a new cable from a 98 corrola in the scrappy and it fits dead on but doesn't work either can anyone gimme an answer to what ones fit please ? will it have to be a glanza speedo cable ? Quote
Bug679 Posted August 11, 2015 Author Posted August 11, 2015 Never mind folks it's working away went for drive instead of driving it on the street lol thanks for the help Sudden 👍🏻 Quote
