Hi, last year i swapped koni front adjustable front shocks and lowering springs a couple of months after.
As of recently, car makes squeaking noises when braking and lifting the foot off the accelerator.
Will replacing the shocks sort out the whole thing? The noise is really embarrassing with passengers riding.
Thanks for your help.
Rock the car and try if you hear where the noise is coming from,
could be anti-roll bar bushes, ball joints
Then spray it will some wd40 or somthing and see if the noise goes away. Hopefully you will find whats making the noise
I did try rocking the car; but it makes no noise when still; only when moving
Sounds more like a ball joint then.
The shocks will make a noise when rocking the car.
Spray some wd40 over the anti roll bar bushes, then drive it. If its still there the do the same to the ball joint and drive again.
Rule them out one by one.
