Bussey Posted September 2, 2015 Posted September 2, 2015 Oil temp gauge, oil pressure gauge, fuel pressure gauge. Rear ARB.Aftermarket inlet. Rear adj. panhard rodAbs delete kit.Cheers
StuDoc 72 Posted September 2, 2015 Posted September 2, 2015 Delete the ABS yourself. 6 small brake pipes is all you will need and 2 T pieces. Will save a small fortune and its easy peasy.
Bussey Posted September 2, 2015 Author Posted September 2, 2015 Delete the ABS yourself. 6 small brake pipes is all you will need and 2 T pieces. Will save a small fortune and its easy peasy.Cheers mate I'll look into it
funny onion Posted September 2, 2015 Posted September 2, 2015 As above- i used the bias valve from a yaris from scrap yard on my glanza to delete the abs
Bussey Posted September 2, 2015 Author Posted September 2, 2015 As above- i used the bias valve from a yaris from scrap yard on my glanza to delete the abs I've got some drinking straws and cellotape at home that will do
jayc-glanza17 Posted September 2, 2015 Posted September 2, 2015 Ive got either a oil temp or pressure one brand still boxed up mate in my garage.depo racing one think its 52mmBut ill have to check matey
Bussey Posted September 2, 2015 Author Posted September 2, 2015 Ive got either a oil temp or pressure one brand still boxed up mate in my garage.depo racing one think its 52mmBut ill have to check mateyLet me know mate and I'll come grab it ASAP
_shaun_ Posted September 2, 2015 Posted September 2, 2015 worth doing your own brake lines and fittined an after market adjustable bais valve on the rear means you can dail in your front/rear braking balence for the track.
Bussey Posted September 2, 2015 Author Posted September 2, 2015 worth doing your own brake lines and fittined an after market adjustable bais valve on the rear means you can dail in your front/rear braking balence for the track.Already ordered a bias valve mate, getting so some else to set that up though, that's a bit too technical for me haha
jayc-glanza17 Posted September 2, 2015 Posted September 2, 2015 What evening you free james?I have a look and drop u a text.
