right, I'm after a steering wheel boss to fit fit my sparco steering wheel..
either I'm not looking hard enough or there none for my 99 glanza? brought one off ebay for £25 which doesn't fit.. any idea on where to get one?
cheers
  • 2 weeks later...
I think that the airbag plug has to be removed when fitting an aftermarket wheel?
Should be four screws on the plastic bracket it attaches to, remove those and then take the whole piece out. Then bridge the yellow airbag plug behind it, so that your light will go out as normal when the ignition is switched on.
Your boss should slip straight on the spindle then.
Edited by uberphil88
No worries, no those four screws are easy to get to with the column still in place. You should see them as soon as the wheel comes off, just some small crossheads.
You should be able to bridge the airbag plug with the column still on too, everything's quite easy to get to!
