chad94 Posted September 24, 2015 Share Posted September 24, 2015 right, I'm after a steering wheel boss to fit fit my sparco steering wheel..either I'm not looking hard enough or there none for my 99 glanza? brought one off ebay for £25 which doesn't fit.. any idea on where to get one? cheers Quote Link to post Share on other sites
Dansstarlet1996 Posted October 4, 2015 Share Posted October 4, 2015 i had issues with mine off ebay, the airbag plug pressed against the earth ring on the boss, dont know if thats the same issue your having? Quote Link to post Share on other sites
Fozzie Posted October 4, 2015 Share Posted October 4, 2015 (edited) I think that the airbag plug has to be removed when fitting an aftermarket wheel?Should be four screws on the plastic bracket it attaches to, remove those and then take the whole piece out. Then bridge the yellow airbag plug behind it, so that your light will go out as normal when the ignition is switched on.Your boss should slip straight on the spindle then. Edited October 4, 2015 by uberphil88 Quote Link to post Share on other sites
Dansstarlet1996 Posted October 4, 2015 Share Posted October 4, 2015 ah i see, thanks phil! I've got a airbag canceller kit so il wire that in, so do i need to take the plastic off from around the column to get to the screws? Quote Link to post Share on other sites
Fozzie Posted October 4, 2015 Share Posted October 4, 2015 No worries, no those four screws are easy to get to with the column still in place. You should see them as soon as the wheel comes off, just some small crossheads.You should be able to bridge the airbag plug with the column still on too, everything's quite easy to get to! Quote Link to post Share on other sites
Dansstarlet1996 Posted October 4, 2015 Share Posted October 4, 2015 ah sweet, cheers! Quote Link to post Share on other sites
