Bug679 Posted October 15, 2015 Posted October 15, 2015 Alright folks ,There's a burbling gurgling sound from the top rad hose after the car stops. I've bled the system after putting in a new heater matrix a couple of weeks ago but this has only happened the past two days. I fitted new water pump and thermostat 17000 Kms ago so don't think that's the problem the only think I can think is fitted a new turbo last weekend could this be the cause of it. The temp handle never rises above the half way mark either. Any suggestions are welcome. This is my daily yolk so need it back on the road Thanks Quote
Bug679 Posted October 24, 2015 Author Posted October 24, 2015 Sorted it's the turbo must of been air trapped in it. Rerouted the water lines to check and its def the turbo. Quote
5e colin Posted October 24, 2015 Posted October 24, 2015 next time use a 2l coke bottle fill it up with water and turn it upside down in the radiator push it down a bit doing this with engine running will drow out air bubbles and push missing water down :) ( cold ) Quote
goldenvtr Posted October 24, 2015 Posted October 24, 2015 easiest thing to remember is the radiator cap MUST be the highest point in the system for it all the work properly Quote
Bug679 Posted October 26, 2015 Author Posted October 26, 2015 Thanks lads, i used a water can and put it in the bottom waterline for turbo to fill it up and hooked the waterlines back up and all was grand after happy days as i took it to mechanic and he said headgasket was on it's way out good to always check things over :)ThanksGood trick with the coke bottle i'll have to try it someday Quote
