starlet charged Posted October 19, 2015 Posted October 19, 2015 would the cams out of a 1.6 corolla be like fitting high lift cams into my 4efe toylota starlet? Quote
Flaminsam Posted October 20, 2015 Posted October 20, 2015 Wrong engine code buddy :/ The lift on the standard cams is a perfect match for the valve size. I've read that if the lift is more than 1/4 the diameter of the valve the flow will not increase. you will be more likely to bind on your valve springs and be more likely to valve bounce at high rpm. It's the duration you should be looking at really. Quote
