starlet charged Posted October 27, 2015 Posted October 27, 2015 is there any such thing as a adopter/harness that alows you to fit the starlet glanza ecu too the standard 4efe starlet Quote
Stu Posted October 31, 2015 Posted October 31, 2015 It depends on the exact setup your 4efe has as the JPM and UK versions vary I believe but no, you cant really adapt them as the two ecus (usually) have different ignition setups etc and usually the 4efte needs a couple more wires that the 4efe harness wont have. You could cut and splice into your existing 4efe loom with the 4efte ecu but you may have to lay extra wires through the loom. I've converted EP91 ecu's to work in EP82's by cutting and splicing as needed. One car I wired up both plug formats at the same time so he could plug and play between a EP91 JAM ecu and his stock EP82 ecu. Quote
