russ78 Posted November 13, 2015 Posted November 13, 2015 (edited) Year:1996/7Model:1996Tax: a few monthsMOT: brand new MOT Full 12 MonthsMileage: 78000Description: here we have for sale with much regret is my forged TD05 Glanza V I'm only testing the water here as I wont sell cheap SO PLEASE DONT ASKengine was forged with the following componantsScat 4EFTE Forged Conrod KitARP Rod Bolts & ACL main, big end, thrust bearingsTMD Cam Belt KitWossner 74.5mm Low Compression Piston Kit with Rings and PinsAthena 1.2mm Uprated Metal HeadgasketOEM Headbolt Kit inc New Washersfull Toyota gasket setfully reworked head with new valve stem sealschemically cleaned honed and crosshatched block rebored to 74.5Gearbox is in very good condition with no crunching comes with a TRD 1.5 Mechanical LSDSome bits in the pics will be sold off seperatly at my own discretion but none that have been advertisedWheels are Rota Auto X 15"Full TD05 WEPR External wastegate turbo kit including rotated TD05 And 38mm Tail External Wastegate water lines + oil linecomes with OEM 98 Spec Front Bumper With OEM Font Splitter 98 Spec rear lightsAutobahn FMIC suited for TD04/5 SetupCusco zero 1 coiloverstheres tons of stuff ive missed but id rather not break it and see it stay on the forumUPDATED SPEC LIST******Malpassi Adjustable Fuel Pressure RegulatorToyosports slimline Rad with fanJD tuning Slimline Rad Mounting KitAir-con RemovedAutobahn88 Front Mounted Intercooler inc HDI Short Route HotpipeTRD Radiator CapSard Fuel Rail AdapterGreddy Turbo Timer8.5mm Red Magnacor Competition LeadsToyosports Catch CanSickspeed Reservoir SocksMagnetic Sump PlugNGK Iridium Plugs Heat Range 855LPH Tuning Developments Fuel PumpAn8 Race Spec Rocker CoverDepo Electronic Boost GaugeDepo Electronic Water Temperature GaugeTwo Gauge Pillar PodTRD Gear KnobWhite Xenon LED interior lightGreddy Turbo TimerForged 4E engineScat 4EFTE Forged Conrod KitARP Rod Bolts & ACL main, big end, thrust bearingsTMD Cam Belt KitWossner 74.5mm Low Compression Piston Kit with Rings and PinsAthena 1.2mm Uprated Metal HeadgasketARP 2000 Uprated Headbolt Kit inc New Washersfull Toyota gasket setfully reworked head with new valve stem sealschemically cleaned honed and crosshatched block rebored to 74.5new Toyota Oil pumpnew Toyota water pumpWEPR SR-series stainless steel manifold with external w.gate outlet with a WEPR Screemer Pipe & WEPR DecatTD05H 16G Turbo fully rotatedTial 38mm External WastgateCAP Clutch Racing Clutch Kit (less than 500miles on this)Blitz Nur Spec Full Cat back System5 Speed Gearbox no crunching comes with a TRD 1.5 Mechanical LSDRota Auto X15" AlloysImpreza Front Setsfull rear interior including carpets trims and OEM furry matsEngine management is Greddy Emanage Ultimate plug and play loom mapped to Sard 550CC InjectorsBad Bitscar suffered turbo failure (which has been replaced now) but still has oil residue in exhaust system also clutch release bearing needs replacing as it has the dreaded rattle, also a little paint peel on driver side wingand wing mirror, way back when car was registered as a cat C but it was just replacement of the rear bumper but if this is gonna stop you buying car this car really isn't for you NOW BREAKINGures:http://s1066.photobucket.com/user/russyb/media/20150102_132722_zpsolu74boi.jpg.html contact Details: pm me ONLY far to many dreamers Edited December 12, 2015 by russ78
russ78 Posted November 17, 2015 Author Posted November 17, 2015 If we can keep posts only to interest in buying guys Many thanks
TimD Posted November 19, 2015 Posted November 19, 2015 (edited) Who built the engine, when and how many miles ago? Edited November 19, 2015 by TimD
russ78 Posted November 19, 2015 Author Posted November 19, 2015 (edited) engines done just over 2000 miles engine was rebored crosshatched and honed by gard engineering and pistons were clocked and installed by Smiths engine builders (with over 30 years experience) the rest was build by just meObviously receipts of nearly everything and all work will come with the history if it sells hope that helps buddy Edited November 19, 2015 by russ78
russ78 Posted November 22, 2015 Author Posted November 22, 2015 this will be broken if engine sells first
russ78 Posted November 23, 2015 Author Posted November 23, 2015 Boost is running 1.3bar and power estimated around 280bhp as not been dyno'd on TD05 yet
Dan507 Posted December 4, 2015 Posted December 4, 2015 I don't get why this is so cheap, I'd want a minimum of 5k
russ78 Posted December 4, 2015 Author Posted December 4, 2015 Just want a break buddy and have another car so need space
TRD Posted December 4, 2015 Posted December 4, 2015 I don't get why this is so cheap, I'd want a minimum of 5k Even for 3.5k n9 one is buying it so imagine at 5k. Christmas season no money.
JDMBenny Posted December 8, 2015 Posted December 8, 2015 How much for the engine just out of curiosity mate
russ78 Posted December 8, 2015 Author Posted December 8, 2015 (edited) 1500 ono buddy Edited December 8, 2015 by russ78
