My car isn't working good.
I have a missfire above the 1 bar of boost.
New 8mm magenecor cables(2000km old)
New ignition rotor(2000km old)
Spark plugs(iridium's 7) are 10.000km old
I changed for a test run 4 iridium 6 spark plugs and the car drives alot better.
I gonna buy some new spark plugs.
Which one should i buy? Iridiium 7 or iridium 8 spark plugs?
My setup is:
Fully forged engine with a td04l turbo on 1.3 bar of boost.
What's the spark plug gap?
Grade 6 will be fine for 1 bar boost, no issue. But he's running 1.3 bar, I assume it's on a programmable ecu? Heat range 7 will be best.
