jmmy6990 Posted November 23, 2015 Posted November 23, 2015 wanted wiring for electric mirrors for a glanza
hookie663 Posted November 23, 2015 Posted November 23, 2015 Do u mean the door wiring if so ive got tat
jmmy6990 Posted November 23, 2015 Author Posted November 23, 2015 I don't no lolI need the wiring that goes from mirror switch to both mirrorsthanks jamie
morgey Posted November 24, 2015 Posted November 24, 2015 If you're putting them in a uk spec you have to wire them in yourself. Theyre build into a glanza dash loom so cant be separated.
morgey Posted November 24, 2015 Posted November 24, 2015 You can take the power from the fuse panel under the steering wheel and earth it out anywhere. Its a case of running 5 or 6 wires over to the passenger side and a similar amount down to the drivers side. You'll want some plugs so you can remove them like with the normal door wiring. And a bit of time with a multi meter working which wire does which. I did make a pencil diagram when i did mine but not sure what i did with it.
