fordie_glanzaV Posted November 27, 2015 Posted November 27, 2015 Mines coming off tommorow.. i can get pics if u want case u wanna grind shit down before fitting your box? Quote
Matthewep91v Posted November 27, 2015 Posted November 27, 2015 Okay cheers fordieLook forward to seeing the out come Quote
fordie_glanzaV Posted November 27, 2015 Posted November 27, 2015 Itl be off tommorow. Update then Quote
Charlie28 Posted November 27, 2015 Posted November 27, 2015 Mines coming off tommorow.. i can get pics if u want case u wanna grind shit down before fitting your box? Pics would be good bud! Quote
fordie_glanzaV Posted November 28, 2015 Posted November 28, 2015 Caused by my spec clutch... 2.5inch in all the way round.. ground down now fine Quote
Scoobysvx Posted November 29, 2015 Posted November 29, 2015 I had the same issue with mine! I decided to file away a small amount from the pressure plate rather than grinding away at an irreplaceable gearbox! My clutch, flywheel, crank and pulley have been balenced individually and as a set since Quote
fordie_glanzaV Posted November 29, 2015 Posted November 29, 2015 Yeh i didnt wanna touch the clutch and throw it out of balance... A few mm off bell housing wouldnt hurt Quote
RobSR Posted November 29, 2015 Posted November 29, 2015 My ORC was tight but doesn't catch. Thats the clutch you want. Quote
Charlie28 Posted December 1, 2015 Posted December 1, 2015 Had a look at mine at the weekend and i don't have any problems with it catching luckily Quote
