gavcollier Posted March 1, 2008 Share Posted March 1, 2008 Ive just come back from Rolling moation in Caerphilly (south wales)Would like to recommend this place,really helpfull and friendlyI dont have a scanner so i cant post up the graph but heres what i had167BHP at the Fly147 At the wheels (iirc) ill check the graph afterMy spec is Hybrid CT9Blitz dump valve RSR stainless straight through exhaust HKS Fuel Cut Defender (FCD) HKS Programmable Fuel Computer F-CON (PFC) HKS Air Filter Greddy Trust front mounted intercooler HKS actuator Upgraded high flow fuel pump NGK silicone spark plug leads Denso IK22 Iridium spark plugs I still have the EFI pipe on so my filter is at the back of the engine bayIt was also runned at 0.8 boostPersonally im disapointed,for the money ive spent it hasnt been worthitI Phoned TurboDave to ask tell him what i got etc,he sounded impressedSo next on the list isDe-cat and get that filter to the frontAll comments welcome( im not expecting them to be good but i would like you to give your honest opinionThanksGav Quote Link to post Share on other sites
Marc Posted March 1, 2008 Share Posted March 1, 2008 gavcollier said: Ive just come back from Rolling moation in Caerphilly (south wales)Would like to recommend this place,really helpfull and friendlyI dont have a scanner so i cant post up the graph but heres what i had167BHP at the Fly147 At the wheels (iirc) ill check the graph afterMy spec is Hybrid CT9Blitz dump valve RSR stainless straight through exhaust HKS Fuel Cut Defender (FCD) HKS Programmable Fuel Computer F-CON (PFC) HKS Air Filter Greddy Trust front mounted intercooler HKS actuator Upgraded high flow fuel pump NGK silicone spark plug leads Denso IK22 Iridium spark plugs I still have the EFI pipe on so my filter is at the back of the engine bayIt was also runned at 0.8 boostPersonally im disapointed,for the money ive spent it hasnt been worthitI Phoned TurboDave to ask tell him what i got etc,he sounded impressedSo next on the list isDe-cat and get that filter to the frontAll comments welcome( im not expecting them to be good but i would like you to give your honest opinionThanksGavSounds just below what would be average for those mods. Your only running 0.8bar so when its turned up to 1bar or 1.1bar you'll see a big power gain. Also you have the cat still fitted, the decat will let all your mods work together better, that decat is just restricting everything bro.Dont be annoyed or anything, i honestly think its the decat buggering things up! Quote Link to post Share on other sites
gavcollier Posted March 1, 2008 Author Share Posted March 1, 2008 cheers matethe main problem is the EFI pipe i thinkneeds to be to the front of the carHybrid with them mods then will be ok to run at 1.2Bar so i am told Quote Link to post Share on other sites
Sparky Posted March 1, 2008 Share Posted March 1, 2008 Yea the decat is what you need mate!!!I thought the only local RR place was Westec in Newport but hasnt that shut down?Decat relocate the filter and up the boost to a bar and you should be seeing near enough 190bhp ;) Quote Link to post Share on other sites
Nick_p Posted March 1, 2008 Share Posted March 1, 2008 For the amount of boost your running and still having the cat in place, I think its not a bad result.Like Marc said once you have a decat, mounted your filter to the front and raised the boost you should see an even better gain. Quote Link to post Share on other sites
gavcollier Posted March 1, 2008 Author Share Posted March 1, 2008 Sparky said: Yea the decat is what you need mate!!!I thought the only local RR place was Westec in Newport but hasnt that shut down?Decat relocate the filter and up the boost to a bar and you should be seeing near enough 190bhp ;)Westec has closed down mate,not sure as to whyWas hoping for teh 200 bhp mark Quote Link to post Share on other sites
Sparky Posted March 1, 2008 Share Posted March 1, 2008 well if the hybrid is rated for 1.2bar you should break the 200bhp barrier fi not you will be very close Quote Link to post Share on other sites
gavcollier Posted March 1, 2008 Author Share Posted March 1, 2008 yea its the one toby sells,i didnt get it off him but its the exact same so i am told by his supplierHope to meet the 200bhp markill be happy then Quote Link to post Share on other sites
RobSR Posted March 1, 2008 Share Posted March 1, 2008 nice result with the cat still in..but i would recommend you get an uprated clutch if you dont already have one ;)Rob Quote Link to post Share on other sites
Sparky Posted March 2, 2008 Share Posted March 2, 2008 The man has a point ^^^ :angry: Quote Link to post Share on other sites
