Fifress Posted December 3, 2015 Posted December 3, 2015 Hello starlet gods, im here to see if any of you cam find/ take a photo of a mk2 cluster/clocks...i recently got a full mk2 loom to put on my mk1 since mine was all f'ed up. (Many thanks to the member who supplied it!) My main problem now is to join the mk1 cluster (2 plugs, all identified) on the mk2 loom wich has 3 plugs and I cant get any info about wich wires do what... Heads up on people attempting mk1/mk2 swaps...a lot of sensors on the engine bay need the apropriate connector plugs, quite a few to replace on looms.After finishing this, i can make up a little guide on everything that needs to be done.Thank you, keep them starlets alive! Quote
Chops Posted December 3, 2015 Posted December 3, 2015 i can get you some pics of the plugs and pcb board gubbins dude, might take a day or two as all my stuff is miles away and im silly busy atm! Quote
Fifress Posted December 3, 2015 Author Posted December 3, 2015 Awesome stuff! Please do...ive been told and I can confirm on the mk1, the rear of the cluster shows which wires go and come from Quote
