decdd19 Posted December 8, 2015 Posted December 8, 2015 How many earth's on these engines an where are they roughly thanks Quote
TimD Posted December 8, 2015 Posted December 8, 2015 I suspect I'm short of a couple, as the only earth I had to undo to get the engine out was the gearbox to chassis. Quote
tommcnaught Posted December 8, 2015 Posted December 8, 2015 Engine mount to chassisStarter motor AlternatorLeft side of inlet cable comes out of injector loom casingGearboxThese are all I can think of off top of my head Quote
decdd19 Posted December 8, 2015 Author Posted December 8, 2015 Sorted on starter alternator and inlet Mani Any idea how thick the wire is or should be off the other earth's Quote
tommcnaught Posted December 8, 2015 Posted December 8, 2015 Pretty sure they vary but just over do it if you need to make a new one as you will only benefit from a better earth Quote
RobSR Posted December 8, 2015 Posted December 8, 2015 Do you mean where the engine/box is earthed to the chassis or do you mean where there is earth points on the wiring loom? Quote
decdd19 Posted December 8, 2015 Author Posted December 8, 2015 Engine an box to the chassis , the ones in the loom are pretty straight forward Quote
RobSR Posted December 8, 2015 Posted December 8, 2015 (edited) Are you having probs with it turning over? Take a look at the latest post in my build thread, i was and made a new earth from the box to the chassis and it sorted it. Ive got some surplus and can make you one if you wish. Edited December 8, 2015 by RobSR Quote
decdd19 Posted December 8, 2015 Author Posted December 8, 2015 No getting it ready to try turn over ha Where are you getting the battery terminals look smart? No mate your grand thanks though was just after there locations an a rough idea of the size of wire as want to make up some the weekend Quote
RobSR Posted December 8, 2015 Posted December 8, 2015 Just a local place then I've got some hydraulic crimpers to put them on and heatshrink them after. I did my one out of 35mm2 so pretty chunky. Quote
decdd19 Posted December 8, 2015 Author Posted December 8, 2015 Ya would want a hydraulic crimps for that ha least it gives me an idea thanks again Quote
RobSR Posted December 8, 2015 Posted December 8, 2015 Yea you won't have a hope of doing them with anything else, even 25, or 16mm you'd struggle i think. Quote
