ROTABOOST Posted December 10, 2015 Posted December 10, 2015 Hi all, Just a quick one. I'm looking at getting a 3 point rear brace. Question I have is the points where it mounts to the rear struts. The GT has the 2 bolts for the coil overs and 2 studs on little brackets. I've been told that the rear braces bolt to these studs? Is that correct as they look quite flimsy and 2 of mine have been snapped off. Ideally I'm hoping the brace will bolt on to the same studs as the coil overs. Cheers Quote
ROTABOOST Posted December 12, 2015 Author Posted December 12, 2015 Can anybody clarify whether the Ultra Racing 3 point rear brace bolts to the coil over studs or the other 2 that are on each strut top??? Quote
AdamB Posted December 12, 2015 Posted December 12, 2015 They bolt on to the Damper unit studs, the same ones which hold the damper to the chassis Quote
