Andyep Posted December 25, 2015 Posted December 25, 2015 So I decided to make a start on the td04 conversion today , I have been getting the bits together over the last six months , been a bit off a fiddly operation but hopefully will have it all fitted by Sunday how it started yesterday Quote
5e colin Posted December 25, 2015 Posted December 25, 2015 looking good kid you will loove the sound of the fse on full song :) what boost will you be running ??? altering fueling w.h.y. as setup i hope that ss toyosports mani is braced or it WILL !!! crack Quote
Andyep Posted December 25, 2015 Author Posted December 25, 2015 Not braced manifold yet waiting to get all pipe work finished, however it's the heavier duty one one not the cheap toyosport one , I have put 380 lhp pump in tank, I do have a twin Bosch set up with swirl tank but not taking that on yet, i put a zisco high flow fuel rail on and an aem fuel pressure reg , not bothering with injectors yet will wait till the 5e is finished, also have got wide and to fit next week as well as hks fuel cut and aem boost controller , Iam running a gizmo boost controller at the moment with built in fuel cut. It drives me mad tho so taking that out Quote
Andyep Posted December 25, 2015 Author Posted December 25, 2015 Going to run bar off boost on standard management for a while , can't decide which way to go management side yet I fancy apexi fc tho Quote
5e colin Posted December 25, 2015 Posted December 25, 2015 ok so its rrfpr and fcd for now , at a bar of tdo4 boost i suggest to set the fuel pressure regulator to 3.2bar and lower if needed be check with your wideband start of rich do some 3rd gear pulls to check afr readings Quote
Andyep Posted December 25, 2015 Author Posted December 25, 2015 Cheers Colin , yeah I was toying with 3 bar+ , luckily my wide band turned up yesterday so will be installing and sorting with the rest off the set up next weekend 👍, I don't mind these little cars , glad I bought it . Quote
