so as in the title my auto gearbox throttle cable is leaking ATF.
i have tightened the cable bracket yet it is pouring out at a massive rate and because its not sealed properly the fluid that was in it hasnt been getting to the torque converter.
i have literally no drive, i can poodle along at 15mph @ 3000rpm but need a solution.
am i best to drain it, clean it and use a silicone/gasket sealer on it?
cheers
