Reeceep91 Posted January 24, 2016 Share Posted January 24, 2016 So the car was driving but became very dead with no power. It started to get worse until I had to keep the revs on it to keep it going. It did run a wee bit better after about 3k rpm. I changed the the full ignition system and fuel system. Also done a compression test and all cylinders came back about 140psi any ideas? Quote Link to post Share on other sites
