Bussey Posted January 27, 2016 Posted January 27, 2016 After a bit of help.Most of the stuff on my shell is now complete, One small issue that I'm now scratching my head on is that I have no wipers, dash ignition or prestart warning lights...Or indicators.Dash illuminates when lights are turned on (minus fuel gauge back lighting), hazards work fine. That's about all I'm getting.All earths in the bay are connected. I know the wipers use the same earth in there as the fuel pump and that's working fine.All three connections on the back of the clocks are plugged in and the speedo cable. That's it.Elp plz Quote
RobSR Posted January 27, 2016 Posted January 27, 2016 Think mine did this when the main 100A fuse in the engine bay fusebox was goosed. Worth a check Quote
Bussey Posted January 28, 2016 Author Posted January 28, 2016 Think mine did this when the main 100A fuse in the engine bay fusebox was goosed. Worth a checkCheers mate that's one thing I haven't checked! All earths are 110% on, all wiring correct. Plus fuel pump works.If it's not the fuses like you've said then I'm seriously lost. Literally nothing else it can be ! Quote
Bussey Posted January 30, 2016 Author Posted January 30, 2016 All fuses checked in the bay and inside.All earths connected as far as I know.Still no wipers, indicators, and no ignition lights.Lights work but no dash display to show this, main beams works. Hazards work, starter motor turns engine over and fuel pump works.So yeah, I'm confused as hell now. Dash illuminates when lights turn on, hazards are displayed on dash when turned on, that's it Quote
