dave_bristol Posted January 20, 2006 Posted January 20, 2006 hi all on the way back from work my 1992 gt turbo started missing, i suspect the plugs but am unable to check tonight as its dark, i need the car by lunchtime tomorrow so need plugs tonight which means i gotta go to halfrauds, please could someone tell me the part number for the plugs i need. would these be correct ? NGK SPARK PLUGS UK NGK Spark Plugs- BKR6EP-11cheers all Dave Quote
dave_bristol Posted January 21, 2006 Author Posted January 21, 2006 went to halfords last night and the bloke didnt have a clue what i was on about, apparently there is no such thing as a toyota starlet gt turbo not even an import ;) anyone have any ideas on what plugs i can get, really need some today even if they arnt ngk, any part numbers would be grandcheers allDaveanyone know if 4efe plugs will fit ? Quote
DAN_GTT Posted January 21, 2006 Posted January 21, 2006 ive got denso iridium's in mine,havent got a clue what the part number is, i will try and find some more info Quote
DAN_GTT Posted January 21, 2006 Posted January 21, 2006 Found this if its any helpStandard ...NGK : BKR6EIX-11 gap to 1.0mm if running >12psi but less than 15psiND : IK20 gap to 1.0mm if running >12psi but less than 15psiModified ...NGK : BKR7EIX-11 gap to 0.8mm for >15psiND : IK22 gap to 0.8mm for >15psiRace ...NGK : R7434-8ND : IK01-24 pre-gapped 0.7mm Quote
DAN_GTT Posted January 21, 2006 Posted January 21, 2006 NGK BKR6EP-11 crosses over to Denso PK20R-11. This is the standard specified plug for the 4E-FTE by Toyota.Toyota now use Denso. They used to use NGK.If you want to use one heat range colder (for higher boost) just use Denso IK-22. Quote
Robbo Posted January 21, 2006 Posted January 21, 2006 the 4efe plugs are grade 5, this is too hot for the 4efte, use 6 standard, 7 for modified and 8 for highly modified (18psi+) Quote
dave_bristol Posted January 21, 2006 Author Posted January 21, 2006 brilliant thanks for the info, went to toyota dealer and they had on set left so i got em,still misfiring though ;) cap and rotor are fecked as are the leads anyone know where i can get these from ? so far camskill are best price for leads (blue 8mm £65)but i cannot find a cap and rotor listed anywhereif dave burwash can get a cap i will buy it all off of him as he offers a great serviceDave Quote
