ive connected the amp to the car battery connected the rear speakers to the amp and connected the amp to the head unit but it aint working theres a wire called ANTENNA/REMOTE CABLE thats got to go from the amp to the headunit but there is not a port on the headunit to put that wire in could some1 please help me in what i got to do to make the amp work as i am a novice in car electricals. thank you.
its a kingstech mp3 with remote if that helps
the block pluge
the wires are
orange (power antenna fuse 0.1A optional)
Red (ignition fuse 1A)
green and green/black (front left speaker)
white and white/black (rear left speaker)
black (ground)
yellow (fuse 8A memory)
purple and purple/black (front right speaker)
brown and brown/black (rear right speaker)
dunno if this helps mate
hiya mate. im ther fitter for halfords so ill find you one. on the loom you got in the back of the stero there should be a blue wire there by its self not connected to anything. thats normaly the turn on lead. it should say rem or remturn on. it dosent need to be behind the stero. it can be on any feed in the car that comes on with the stero. or you could put in on a switch and turn it on when you want it to. if you still have probs gimme a shout.
<{POST_SNAPBACK}>
dont worry mate i found the wire and connected it up sounds well beefy cheers mate 4 the help you is a legend. cheers. :lol:
