Tiger31
    15
    Dublin
3327 profile views
Tiger31's Achievements
  1. Looking for a Quaife LSD to suit a Starlet 1.3 N/A Call or text to +353 87 115 1462 Thanks in anticipation!
  2. Fault traced to the ABS pump. Sorted now
  3. Looking for some advice on ABS bleeding. I've replaced left front caliper, but not getting pressure. Any advice welcome.
  4. Thanks guys for that info. The door sticker quotes both 13" and T105/70 14, which suggest 14" as per BMX-Rig. I need to be able to show that it's OEM on 14", so I'll go with the sticker info. Cheers
  5. My Glanza is running on 175/65 x 14" steel rims. How can I tell if 14"is the original wheel size, as some lists quote 13" rims for Glanzas
  6. HI, I have noticed two unused female sockets on the harness, to the front of the radiator, details as follow: Car: 1997 Glanza S (non turbo) 1. Drivers side socket: 2 wires Red/Blue and Red/Green 2. Passenger side socket: 3 wires (lighter) Red/Yellow; Red/light Blue / Black/White Would anyone know what these sockets are for? Thanks in anticipation
  7. Yes, lack of lubrication sound like the cause. If I can't sort locally, I'll come back to you on those hinges. Cheers
  8. Dorman in USA do repair kits, a bush and pin, like you suggest, but Starlet is not on their list. I may have to resort to a pair of hinges. Cheers
  9. Does anyone know of a repair kit option for a dropped drivers door hinge? I've seen a pin and bush kit for some makes, but not come across a Starlet kit. Thanks in advance.
  10. Thanks Gorganl2000. That sounds like the one I want.
  11. What LSD unit would be a direct fit into an EP91 5 speed box on a Starlet. This one is out of a Levin, OEM fit, 8 hole casing fit?
  12. Hi... What type of LSD have you for sale?
  13. Thanks Richard .... Lots of useful info and tips here ....... Great site..... I'm near Dun Laoire,... far side of town Regards.
  14. Hi, just found your website, looks like a great source for technical info etc. My Jap import 16v is used for auto tests when not shopping! Hope to find some details on LSD's and other light tuning. 🚗
