  • 9 months later...
Might be a bit late of a reply now but you will need the complete rear axle and everything attached to it,
including handbrake cables, calipers & discs and brake lines (as the turbo models have a total of 4 brake lines at the the rear)
If you get hold of one, it might be worth fitting poly bushes before fitting it, and check the bearings are good too, maybe even overhaul the brakes as they are prone to seizing
