Evo_stevo
    64
    Scotland
Evo_stevo's Achievements
  1. My wife occasionally drives my silver Glanza v but only if she has too as she prefers her own car. I've seen the black one about Dundee aswell, Someday I'll make it into the spotted section
  2. Cheers for reply mate, I'll give it a go see if it fits. The locks not seized or hard to operate, if anything it's worn and become fiddly to use. The passenger side is good on the other hand with not getting used so a swap would be ideal.
  3. The drivers door lock in my ep91 Glanza is a bit tired and some times requires abit fiddling to get it to open. The passenger door is very smooth and operates no problem and feels very tight. I'm going to remove the horseshoe clip that holds the lock in and tighten it a bit but I wondered if I can swap the lock from the passengers door onto the drivers door?? Does anyone know if this can be done before I try it??
  4. What's your budget?
  5. I'm looking to sell mine soon mate, Its a 97 Glanza v on a p reg 170.000kmh on shell and 1300 miles on a new forged engine it has 11 mths mot 5 mths tax its ao1 silver with a new ct9 turbo new 6 paddle clutch forged rods and pistons and reg round crank many new parts all new brakes and handbrake cables new plugs and leads and battery, 16" wheels and a spare set of 15" enkie's fitted with a cat and new lambda sensor but comes with a decat. Hks exaust blitz turbo timer, Would accept £2000 for it or I'll advertise it shorty nationally for £2450 Ono. Only selling to start another project let me know of your interested I can send some pictures and more details.
  6. Ha ha as an evo owner I think its god awful and the colour doesn't help. It got the same reaction as here over on the mlr forum. Edit: as mentioned I think its running 600+ hp or something crazy... It's got a very wide track aswell looks like 9.5 or 10" wide wheels.
  7. My glanza's mot'd and on the road but I'm working Saturday nite so will miss this looks good too Would have brought the Evo and Glanza both like getting their picture took
  8. Yea cheers for that dude, I'm familiar with both them places from my Subaru days. Ill nip thru to checkpoint garage in Arbroath with it or Wallace performance in Aberdeen but that's a good bit further. It's back in for mot tomorrow the emissions are "better" I've fitted the cat and ill inform them it doesn't need a full car test...... Maybe test a car nearby that's 15 yrs younger Should be ok hoping it passes and I can get out in it. I'll be able to drive it thru to Arbroath to get the boost issue sorted once its mot'd and I swap the insurance from Evo. Snows coming so that's it off road till April now
  9. What group or page is it? I'll have a look
  10. When and where? I've not heard of anything going on
  11. Gbr Motorsport is no longer trading, spoke to the lad today who was very helpful. He informed me that he was working full time for toyota and didn't do any other work .
  12. Cheers fella Just looked them up on the net cheers for thatm,ill give them a ring tomorrow they would be the obvious choice given their knowledge with the starlets and probably a bit closer to me Never knew about them cheers ;)
  13. Bump.. Can anybody spare an hour or two this week to have a quick look over my Glanza? I'll be fitting a new abs pump on Wednesday and I just need to get it boosting properly to get it back in for its mot. Also can anybody get me a link I can print out for the mot station re: emissions tests for 4efte engines. Thanks in advance
  14. From what I know its its got a ct9 turbo a sard fpr the filters been relocated and that's about it I think. It's also got forged pistons and rods and a new crank. It was fitted with a decat but since fitting the cat it seems to run slightly better?? The problem persists in every gear at 4000rpm just as its coming on full boost, I'm a panelbeater to trade so slightly out my depth after checking all the obvious things fuel pressure and the waste gate actuator. The turbos brand new and the waste gate seems to be working on the actuator arm. I was unsure it needed it an uprated fuel pump but the tune up guy adjusted the fuel pressure back down to 2.5bar and it seems to be getting enough fuel. I don't have the oem pressure regulator. I think once the boost issue is sorted it should pass ok. The tune up guy measured the temp of the cat it was 300* @ the lambda but only 200* at the bottom end of the cat he said it needs to be an even 300* to function properly. Think I've seen this before do you have a link I can print off for the mot station??
  15. There's obviously ££ in this for someone to get it sorted or at least diagnose the fault. I'm not expecting anybody to spend time if there's nothing in it for them. I wouldn't
