TD04HYBRID
    700
Everything posted by TD04HYBRID
  1. Been looking into it but what size tank would you get!
  2. Cheers mate quite expensive to do the one part though!
  3. Cheers Colin Could do but I can do carbon wrapping myself think it will look better flocked what's people opinions? Do you know some Lwhere that carbon dips
  4. Cheers Ryan! It's getting there hopefully a base map in the next couple of weeks and full map and dyno by end of June if all goes well
  5. Hi all, Today been working on my centre consol getting everything in the right place and ready to be flocked let me know what you think
  6. Thanks mate ideally I want to take them all off the main loom anyone know????
  7. Installing my Depo Race Gauges just wondered it anyone knew the colour of wire on the main harness for the following Battery live- Battery negative- Ignition switch- Dash lighting- Much appreciated Ray
  8. No mate only Fronts sorry
  9. This is disconnected from the car now
  10. Price drop £45 delivered
  11. Cheers Phil! Getting there mate hopefully all will be ready for base map in next couple of weeks if all goes we'll and full map end of June see what power she's pushing
  12. Another Update for you guys............ After sourcing a lot of parts and speaking to Keith at Zisco i decided to get the car ready so i can start getting it on Track and maybe do some of the last session of the Toyota Sprint Series With the great help of both Keith, White Noise on here and Tuning Development i managed source the following Parts. While waiting for Keith to do his magic i thought ill get the engine looking as good as possible and ready for the new kit! What a nightmare i had removing the old exhaust the bolts had been rounded off and rusted on! (car had been sitting for 2 years before i brought it) I got to this! So tonight it all began! I decided i would get the kit on as best as possible and noticed that i have come across 2 problems. 1 being the water pipes to the turbo are hitting the creamer pipe (going to get heat wrap for the pipes) and the oil return had moved from the standard position so need to order a 90 degree bend slightly longer then standard that i can cut down and make work! And decided to fit my C'S Short Shifter Spec List at present! Engine: 74.5 mm ross forged pauter rods polished and knife edged crank lightened pulley all new bearings and seal new cam belt 2mm Multi Layer Head Gasket Fueling 470cc Injectors 255l Walbro Fuel Pump TD High Flow Fuel Rail Sard FPR Cooling AutoBahn Front Mount Intercooler Alloy Civic Rad Relocation Air Filter Kit(Come out just behind grill) Turbo: TD04 Hybrid Lateral Performance Full HKS Hi Power Exhaust System Up Rated Exhaust Hangers Zisco Cruise Manifold Externally Gated Turbo Smart Wategate Zisco Screamer Pipe Zisco Decat Transmission: spec 6puk paddle clutch TD Light weight flywheel C's Short Shifter Electronics: E-Managed Ultimate Depo Racing Oil Temp Gauge Depo Racing Oil Pressure Gauge Depo Racing Water Temp Gauge Start/Cut off switch Fan toggle switch Fuel pump toggle switch HKS EVC 6 Boost Controller Chassis: 6 Point Carbing Roll Cage Polycarbonate Sunroof BMW E30 Wheels Cusco Front Strut Brace Poly Engine and gear box Mounts White Line Front Anti Roll Bar White Line Rear Anti Roll Bar BC Coilovers RSR Pan Hard Rod Brakes 4 Pot Wilwoods Braided Lines Vented and grooved disc Yellow pads Comments Welcome!!!
  13. If you want mate I'll pick it up tonight and ship it for you?
  14. Each to there own fella!
  15. Cheers fella
