TD04HYBRID
    700
Everything posted by TD04HYBRID
  1. Yeah but some times the alarm flickers but then nothing! I'll take the two main fuses out and test continuity to check there fine! If there not where can I purchase them from?
  2. Been doing loads of work on the starlet over the last 2 weeks and have had it started since the work been done. However today I disconnected the fuel pump connecter on top to test for the live feed! (Some starlets fuel pump don't purge until crank) and mines one of them. So cranked the engine over with te connecter off several times and the battery seem to be giving up so stopped! Put the connecter back on key in ignition all lights came on dash but wouldn't start battery seemed dead so jumped started it and started fine. Left it running for a good half an hour turned it off went to switch back on but had no power and also won't jump start either! Any ideas? As battery is only 4 weeks old? And thought that it would still jump start even if battery was fucked Starting to lose hope with this
  3. Hi all, To save me testing the connecter can someone tell me the live cable for the fuel pump? Thanks Ray
  4. Do you think that will be the cheapest way of sending to Ireland via pallet service? Who do you use?
  5. Pm me your address and I'll get a cost mate over the next couple of days
  6. I would but would have to get a cost for you or you can arrange a courier
  7. £90 if picked up this week
  8. Starting to all come together now! Gearbox is all back on, driveshafts! Wilwood 4 pot brakes with grooved disc and yellow stuff pads in front, braided lines on rear all bled and tyres on! Noticed rad is leaking so new one on the way and thought I would check the thermostat is fully functioning noticed the seal had gone so need to order one! Toggle switches still need wiring up and then thinking about spraying inside and cage! Will get up some pics once it's had a good clean!
  9. As above let me know Ray
  10. Got front hel braided lines in blue pm me a offer
  11. Need them gone just taking up room offers people! They will fit all starlets
  12. Bump! Are these too expensive
  13. What do you guys think are the best gauges?
  14. Thanks everyone for the comments it keeps you wanting to keep building even when things don't go right!
  15. So While i waited for my clutch & flywheel to come i started to custom make a gauge and toggle switch holder and start running the wires through. Then done a template for the gauges and switches Then Carbon Wrapped it Toggle switches! Then turn up 3 packages Spec 6 Puk Clutch/TD Lightened flywheel & HKS Hi Power Exhaust System All bolted on Will keep updating as best as i can
  16. Bump offers need them gone
  17. Bump offers?
  18. As above can anyone help me locate the fuel pump relay?
  19. Need the ignition wiring diagram and the fuel pump
  20. Yeah do you happen to have the fuel pump wiring diagram ie where the relay is?
  21. I got full back interior for gt
  22. Hi all just wondering if anyone happens to have a wire diagram for ep82 quad light ignition wiring diagram will be good Thanks Ray
  23. The vent is out and expanding foam has been used behind it! To stop heat getting on the controller. Everything else is in place
