BIGGFOOT
    225
    manchester
3243 profile views
BIGGFOOT's Achievements
Member (4/8)
  1. im selling a jd tuning torque dampner in adonised blue
  2. Bump
  3. as above located Manchester cash waiting
  4. Hi got oem lsd gearbox with mount and shafts just been rebuilt £650 or Corolla g6 6 speed gearbox (can swap bell housing and run this in ep)£250 or Standard glanza gearbox low miles, still on car no crunchy nut gearchanges lol £150
  5. Hi got aftermarket stainless Ct9 mani for sale £50 posted to uk can send pics etc
  6. Hi I have a set £30 posted
  7. How mmuch mate? And is it for LSD or non? I need both dude
  8. As above need 2 rear gear box mounts ive got a lsd box coming up for sale just refurbing it and rebuilding 1st
  9. I've got a decent ct9 unit for sle £90 posted also ss ct9 mani £65 pal
  10. Hi got a ss ct9 mani for sale pm me for more info and pics
  11. Try it without the electronic boost controller and possibly go external wastegate pal mines boosting hard now on 10 psi with a manual tap type boost controller set up on vacuum line before ex wg, hope this helps mate .... What ecu are you running?
  12. I've sorted it with a manual boost controller tap type thing? (Not sure what it's called lol) plumbed it into my external vacuum pipes and works a treat now at 10 psi pulling hard lads 👍 also check your external isn't leaking ,I've popped a new 38mm gasket in to be sure of no leaks
  13. the rear gearbox mount could be exaggerating it pal mines the same atm get a polybushed one ive been told
  14. Lost two front centre caps off 14" tc305's as above centre caps needed asap cash waiting 👍
  15. Allright lads I'm having same problem on emb(just fitted) but I haven't got a boost control unit but I'm running external wastegate is the spring inside wastegate only thing that could of gone wrong? Any help much appreciated 👍
