Pete EP82
    7
    Waterford
Pete EP82's Achievements
  1. That'd be mine alright....thanks for the feedback!
  2. Hi Guys, Some time ago i bought a Power FC, It's only now that were getting around to fitting and mapping the unit. We are running into an issue with the throttle position sensor. The sensor is showing 1.2volts on the hand commander and will not change from 1.2volts regardless of throttle position (opening or closing throttle). You'd imagine the sensor is buggered but we changed the sensor and are still have the same issue. Wiring going to the sensor appears to be fine also. Has anyone encountered a problem like this before? Any help greatly appreciated!! Pete
  3. Hi mate, great to see another track spec'd EP competing in motorsport. I run a Time Attack EP82 here in Ireland. I'd love to make it over to a round in the UK in the near future. Keep us updated over the coming months. Pete
  4. http://www.tegiwaimports.com/select-car/toyota/starlet-glanza/drivetrain/hel-braided-clutch-line-toyota-starlet-galanza-rhd.html
  5. The line you bought above advertised to go from master cylinder to slave cylinder looks wrong, the 90° male end will most likely fit the slave cylinder but the but the female end is the wrong fitting for the master cylinder. This line also looks too short to run from master cylinder to slave cylinder. However....over the gearbox the clutch line transitions from solid hose to rubber hose, the fitting you have above should connect into the male fitting on the solid hose where the line changes from solid to rubber, eliminating the rubber hose and the solid hose running over the gearbox to the slave cylinder. Pete
