kevy-glanza
    14
About kevy-glanza
  • Birthday 08/06/1986
    Cambridge
kevy-glanza's Achievements
  1. Hello people, I have a slight problem that has started recently; Iâ??m very happy with the car at the moment, and apart from the following it drives and pulls lovely. All of the mods have been on there for at least 2 months (most of them for at least a year). When I have been driving my car for about 45mins, if I come to a stop and have to pull away the car will hesitate and try to cut outâ?¦ after a while it will definitely die and itâ??s pretty embarrassing. But when you leave it for a good hour or more, itâ??s fine again until it all starts happening again. Now, itâ??s not a misfire, but it just dies. I have changed the distributor and rotor, the plugs are fairly new, and the leads are working fine. I have tried another MAP sensor which I know works fine (I am in the fortunate position of having two Glanzaâ??s at my disposal), and there are no fault codes to give me a clue as to what this might be. The fuel cut defender is also wire in correctly (directly to the ECU so inside the car) because it has been awesome up until nowish. Itâ??s weird because this is an intermittent fault, as in it only does it when itâ??s been running for quite a while - but ultimately it means my car has a range of anywhere within about half an hour, which is nice. If anybody has any useful input it would be much appreciatedâ?¦ Oh, and to try and avoid any of the usual first questions, the spec list for the engine reads as follows; 1996 Glanza V NGK iridium plugs Magnecor blue leads GT spec CT9 turbo Meshed intake HKS actuator (1bar) Jam Racing FCD FSE fuel pressure regulator Tuning Developments fuel pump Tubular manifold Gutted OEM cat Japspeed eggsauce Japspeed front mount intercooler Samco coolant hoses Open breather Thanks Kevin
  2. This looks properly sweet in the flesh... saw it at Santapod a few months ago and had to take a few piccy's of it. Well done sir! Kevin
  3. I've got to do this again because my previous feedback was fine but... I've had this on my car now for a good 20 months, and for the past 3 I've been running 1 BAR boost (even tried 1.2 for a bit and that felt savage) and I'm in love with it again. I only got it as a replacement initially, but having put together the bits needed to actually have some fun, and finally turn up the boost it's brilliant. The engine bits on their own are as follows; GT Spec turbo Meshed intake HKS actuator Tubular stainless manifold Modified down-pipe Japspeed exhaust Japspeed intercooler No BOV New OEM rad Samco rad hoses Modified breather NGK plugs Magnecor Leads FSE fuel pressure regulator Nick Jones fuel pump Jam Racing fuel cut defender Boost starts to come in nice and early but builds up progressively and comes in so smoothly - and the noise is immense. Now, I'm not sure what power it has now, and to be honest I don't think I really care too much but I'm very, very happy with it as it is for now. All I'd like next in terms of engine tuning, is a proper ECU and some more boost, but that'll have to happen when funds allow again I guess. Kev
  4. High is 0.6 bar/9 psi and low is 0.4 bar/6 psi. I removed my restriction as soon as I found out about it and it seemed to come on a bit quicker and a lot stronger - gave a touch more boost too. It's a worth while thing to do because as the others have said you can just drive sensibly when you're not in the mood. . . Kev
  5. Howdy Tim, I've seen this car in person at the Japshow Finale, and it's mint. . . you're a good chap to talk to dude. All the guys and gals on the TB Developments stand were sound and welcoming too, that was a good day. I'm just glad it wasn't quite parked next to mine otherwise I would have been jealous :-) Kev
  6. If your missus has any nail polish remover lying around, that stuff works a treat. . . Kevin
  7. No problem dude, I'll have a little looky and get back to you on Monday. . . Kev
  8. I had these on my silver Glanza a little while ago, i really liked them and they were surprisingly light really. jonnyoldroyd - I could send you a pic next week if you give me your email address. Kev
  9. Ah, I see. . . I thought you were looking to get rid. See ya soon.
  10. Hey Jean, Hows things? Freya's EK4 should be going to a new home on Saturday if all goes well. . . and she's looking to get a Glanza, preferably in white. She ideally wants one with all the basics on. You'll see her on Friday so have a chat with her first before you go getting rid of it. Kev.
  11. It's about time that I did this so here it goes; I ordered the GT Spec hybrid when my standard CT9b decided to slowly but surely give up. It turns out that Enzo is indeed a good chap and easy to talk to when you've got questions - the turbo itself looks sweet by the way when you first get it out of the box. I put on the new turbo and took it for a spin and was confused as it felt the same but didn't run out steam high up. I need to explain that this was on the standard poo actuator (I was waiting for mine to come through the post), and I suddenly realised that this was while it was boosting to just 0.5 bar - this felt the same as my old turbo which always crept up to 0.8 bar. I finally got the actuator on and holding a steady 0.7 bar of boost and it feels alot better. I keep increasing it up slightly to try and get it to 0.8 bar until I get to do some more shopping. Considering that I'm currently on a stock manifold, gutted cat and standard exhaust it still hits full boost (0.7 bar so far) by just before 3500 rpm. Anything within 3500 to 6500 ish and I'm consantly grinning. I've never been able to use pretty much all of the available revs because there wasn't any point before. The other thing is that I used to suffer from really bad boost creep, even when it was completely stock (minus the boost restriction) and that has completely gone too, even with not much on the inlet side. All in all I'm a very happy bunny and feel that I have made the right choice. I just can't wait to sort out the entire exhaust and up the boost and fuel. Kevin
  12. I had my girlfriends 16x8 Rota Cups on my Glanza for a few weeks, they look rather deep because the dish is like 5 inches. But I couldn't quite get full lock and it scrubbed more often when you hit certain bumps. This was with Tein springs - it did look sweet but I didn't like driving it as much.
  13. camping over the wknd 1.Enzo, plus five mates 2.Rick 3.Mikey Jay 4.colin aka BoostJunkie 5.Kevy-Glanza Saturday 21st Sunday 22nd
  14. I'm sure it's for 3 days (2 nights). Can I join you lot because my girlfriend will be on the Yaris Club stand and my Glanza might feel left out and get moody? And if you get on the stand, do you need some kind of pass?
