Rob_00
    44
About Rob_00
  • Birthday 11/17/1986
  • MSN
    r_gibbs10@hotmail.com
    Leicester/Norwich
Rob_00's Achievements
  1. would the bushes be easy to get? i would be interested
  2. any chance of getting one of these?
  3. even when i click remember me, i have to sign in each time this is the only site it happens on
  4. i take it back, 9005 do fit quad light if you remove the rubber ring and file down
  5. yes but the bulb design used for the quad light is not widely available anymore. i guess you dont have a GT based on your bulb choice . the base around the "new" bulbs is too big so it wont fit in and the fins are wrong (although they are easy to mod)
  6. the bulbs wont fit into the quad lights. believe me, they are not worth the hassle. only bulbs from toyota will fit as i found out
  7. what bulb will fit the main beam of my starlet GT? Its HB4/9006 the halfords one does not fit, it has a metal bit around the bottom of the bulb so you cant push it in
  8. if your buying off ebay i recomend you buy off a UK based seller and get a warranty otherwise it might be a very expensive hassle i bought my set off ebay from a UK seller with a 24month warranty. Il post up here when i get them, if they are any good
  9. H4 bulbs have high and low beams in one bulb (kind of) so if your car has H4, you would need "high+low". the quad light GT has 2 sets of HB3 bulbs so the whole high-low thing doesnt apply i bought some HIDs today what car do you have?
  10. it will only be a restriction on db levels id of thought they could only implement a standard level (like 100db+) which would be illegal, but it would be pritty loud, think how loud a zonda/ferrari is
  11. how does this metal bit come off? do i need to take the door off the door hinges (please say no)?
  12. well toyota say i have to wait till tuesday now before they can even look at it has anyone here taken the door apart? how do you do it? or is there a way to get the motor/gearbox out easily?
  13. I've given up, seem to of got it stuck and have ended up with 2 spare bolts lol off to toyota then ... DAM WINDOW!!!
  14. how do you get this bit off?
  15. HELP! my drivers window only goes up about 3cm then gets stuck. The motor seems fine since it still goes down and back up the small bit. Pulling it doesnt help, seems quite stuck when it stops. the idle revs die a bit aswell when its moving, where as the passanger side doesnt do that
