customep-82
    8
About customep-82
  • Birthday 08/17/1983
  • MSN
    pasalaqua_exists@yahoo.co.uk
  • Website URL
    http://
customep-82's Achievements
  1. hi mate, so far the only work i had done for me was the machine work on the block, everything else is me
  2. some interior shots for you all and my new Cruise gear knob
  3. both cars look very nice mate second set of rims on the glanza look better imo tom.
  4. thanks for all the comments peeps and sorry for posting in the wrong section shelly i should know better really lol @ sparky, it's one of sacha's td04 kits, but i ditched the turbo to go for a bigger one as the td04 wouldn't give me the power i'm after here's the spec for anyone who's interested spec: engine 75mm ross pistons pauter rods 1.45mm headgasket new main and big end bearings all new oil seals throughout lightweight bottom pully new starter motor 550cc injectors oil catch can apexi power filter GReddy/ Trust oil cooler with filter relocator sard thermostat samco coolant hoses tdo**** turbo(i'll spill the beans once i've dyno tested it ) wepr td04l manifold and downpipe wepr fmic wepr dual core rad tial 38mm w/g and dump pipe toytuning rad cooling panel magnacore ht leads hgk iridium plugs (heat range ajusa headbolts lightweight flywheel new engine backing plate full gearbox rebuild + trd helical diff and alot more i've prob forgot lol electrics GReddy emanage ultimate (c/w support tool, injector, ignition and map sensor harness, 3 bar map sensor and knock sensor adapter) GReddy egt guage GReddy boost guage apexi avcr apexi power stabiliser custom made electronic fan controller kenwood headunit and front speakers plasma dial kit wheels/handling/braking sparco racing rims (15") eagle f1 tyres trd coilovers tein adjustable top mounts cusco rear strut brace cusco lower arm bar cusco side bars cusco bmcs whiteline front upper strut brace rsr panhard rod custom made anti-lift plates braided brake hoses all round levin calipers on the front corolla front discs mr2 turbo front pads standard rear discs and pads new bmc whiteline front and rear anti-roll bars zep "c" pillar bar new bottom ball joints new track rod ends exterior front bumper cut and meshed reverse scoop zep fenders custom corner splitters interior rear completely stripped carpet and sound deadening removed from the front and replaced with acoustic carpet starlet armrest cruise gear knob momo steering wheel 3 point harnesses one both front seats i think thats the lot
  5. this is turbo stall http://www.youtube.com/watch?v=zSIf0IwdiK0
  6. at 241.4mph it'll do that 12 mile freeway in just under 3 mins you could pop down the shops and back in a matter of seconds
  7. thanks for the comments @ BoostJunkie, yes mate i'm on austarletclub. my rod gave way and put three holes in the block block: piston: crank and what was left of the rod:
  8. hey guys and gals, just joined up and thought i'd say hello there's some very nice ep's on here i recognise a few names off TGTT where i'm usually found. anyway here's a couple of pics of my starbo, which i'm still rebuilding lol hope you like Tom.
