Craigtrials95
    59
    Inverness
1862 profile views
Craigtrials95's Achievements
  1. After a set of 15x7 wheels must be 4x100. Ideally after something along the lines of enkei rpf1s or similar Cheers
  2. Im possibly planning trying this myself too but my problem is i cant see the images hahah. comes up saying 3rd party hosting anyone able to help? cheers
  3. Needing a lsd either in or out of a box must be mint condition no shit. Cheers
  4. Just wondering if there is a specific seal for the front windscreen or what seal to get/use? Getting the window removed so I can clean up a small bit of surface rust so would like to get a nice new seal for it. Cheers Craig
  5. Cheers lads vf035 turbo so probably go for a 0.8 bar spring
  6. Going to be running externally gated setup on my 5e once its built and ive never had an external setup before so after some info. If i get a wastegate with say a 0.8 bar spring i can then up the boost to 1.0 bar and 1.4 bar with an electronic boost controller? Thats my understanding anyway just want to make sure its correct Cheers Craig
  7. I'll probably just loop my rack and see how it feels if not try source a non pas rack. Does it need to be secured or high pressure hose to loop the rack?
  8. How is the steering feel with the rack looped? Is it easy enough for a weekend toy and track day car? Could still be an option yet
  9. Cheers lads. Just want it switchable really for manevouring the car and have it off for fast road and track. Surely the steering feel is better when the pump is off? My pump has the built in reservoir too so feels like it will be a tight fit
  10. Cheers. Yeah that's where I've roughly planned in mounting it. The filler neck of bottle fits through where the abs pump sits. But the fittings for feed get in the way off chassis leg
  11. After some help and advice with the electric power steering pump from a saxo. First off where have people mounted the pump unit and any photos? How have you wired it in? Ideally I'd like mine on a switch so I can shut it off Cheers Craig
  12. Looking for people's opinions on a flywheel. My engine is off to get built Monday 15th of this month and it would be ideal to get the clutch and flywheel balanced at the same time. Fully forged 5e and hoping to be fit for 350bhp. Will the standard flywheel be ok or will I need to look into a better one? Also what clutch would people recommend Cheers Craig
  13. Hey, I'm going to be running 282 8mm lift tmd cams in a 5e. Just wondering what's the best uprated springs to buy and is there stronger valves etc? Rev limiter will be getting raised too Cheers Craig
  14. Spot on mate I've had a look on his thread and gave him a message cheers
  15. How does the ecumasters emu wire into the starlet I'm guessing it won't be plug and play?
